It is currently Thu Oct 22, 2026 7:04 pm
Vehicle: sj80
Post Posted: Mon Jun 29, 2015 1:00 pm
This is not your standard asking for help thread, so I'm unsure if I've put it in the right area, but here goes..
I'm about to buy a "factory" AC kit for my SJ80, but I have no idea what to expect, so I wanted to check out an already-installed A/C setup so that I can protect myself from being ripped off.
Is there anybody located around SE Melbourne, with FACTORY installed SJ80 AC that I could swing by and have a glance at?
Cheers.
Post Posted: Wed Jul 01, 2015 5:55 am
There isn't much to it.
Compressor and bracket.
Front crank pulley and belt.
Hose to condensor/drier.
Hose and pipe to firewall.
Under dash unit (evaporator)
Small wiring loom and switch.
Vehicle: sj80
Post Posted: Thu Jul 02, 2015 3:11 pm
I guess I'd like to see how it all actually fits together.
I was told you have to cut the under-glove box tray in half to fit the evaporator, and I can't find any decent pictures of what it all looks like on an sj80
Post Posted: Sat Jul 04, 2015 8:10 am
Cutting the shelf is the easiest part of the whole deal. If you have concerns about that then you should consider getting someone else to do the install.
Vehicle: sj80
Post Posted: Sun Jul 05, 2015 1:28 pm
It's just an aesthetic thing, the work will not be a problem.
As can be seen in these photos:
Nothing has had to be cut.
Main issue is that I cannot find the A/C manual for Sj413/SJ80 anywhere!
Incredibly odd move that suzuki decided that A/C wasn't important enough to be included in the standard FSM, it means that I cannot find any trace of this document anywhere online :/
I've found the one for the SJ70, but as you can see, it's definitely a different install.
Users browsing this forum: Google [Bot] and 95 guests
