[ 7 posts ] |
Print view
Previous topic | Next topic
| Author |
Message |
Bush Pig
Joined: Sun Jun 21, 2015 10:21 pm Posts: 41 Location: Perth
Vehicle: Suzuki Vitara SV420
 Posted: Sat Jun 27, 2015 12:03 am |
Hi all,
Just looking for a bit extra power on my 1.6L Vitara. Enjin is still stock standard, just thinking of an carburator upgrade ? Any simple suggestions ?
Reubs
Joined: Wed Sep 09, 2009 11:30 pm Posts: 1522 Location: Brisbane
Vehicle: SJ80, SE416
 Posted: Sat Jun 27, 2015 1:07 am |
Your profile mentions a '98 Vit. All Vits in '98 were EFI - so no carburettor.
How much work do you want to do to get a 'bit' of 'power'? Done the mechanical basics?
Bush Pig
 Posted: Sat Jun 27, 2015 1:21 am |
Hi Reubs, was just a typo. Fixed it now.
I don't want to open the motor for now. Thought i could just put a DCD Weber on or something ? Just bought it, done nothing yet. What would you recommend ?
unfinished
Vehicle: 91 Vitara SWB Soft Top
 Posted: Mon Jun 29, 2015 8:22 am |
I fitted a 6in x 2.5in round air cleaner and ditched the factory air cleaner and i gained 2 seconds off my 0-60kmh time, i went from 9.5s to 7.5s i am also booked in for extractors and a new exhaust next week and i changed the vacuum secondary pipe to constant vacuum and apart from a big flatspot on full throttle it goes so much better on the freeway
those times are with 31in m/t's fitted 0-100km went from 26s to 22s too also if i do a dirt road or weekend 4x4 trip i'll put the factory aircleaner back on so i don't get water and mud in the carby.
i tried running different fuels and advancing the timing but didn't get any noticeable benefits, so standard timing and 91 octane is all i need
Gwagensteve
Joined: Thu Feb 26, 2009 10:30 pm Posts: 13013 Location: Melbourne
 Posted: Mon Jun 29, 2015 8:42 am |
Unfinished- you're leaving a lot of torque on the table if you don't advance the timing for 98 octane.
unfinished
 Posted: Mon Jun 29, 2015 8:57 am |
i did advance it but it didn't go any better, i get the same performance on std timing and 91 octane, i'm sure once i get the extractors and with the new air cleaner it might have more of an effect
SuziBlu
Joined: Mon Sep 14, 2009 11:30 pm Posts: 4268 Location: Eyre Peninsula
 Posted: Sat Jul 04, 2015 12:49 pm |
How much advance did you add, when I was playing earlier, 32/36 weber, hot ignition, and extractors, found much better go by upping initial timing to 12 degrees BTDC, I also went to 1.1mm gap plugs not the 0.8mm stockers.
_________________ Bad decisions make good stories.
[ 7 posts ] |
Users browsing this forum: No registered users and 134 guests
