It is currently Thu Oct 22, 2026 7:03 pm
Vehicle: Vitara 1.6
Post Posted: Sun Jul 05, 2015 7:53 pm
I found somebody on here claiming to have put a LWB tank into their SWB.
This goes against every other post on here saying it can't be done of course...
They mentioned a custom shock bracket anda couple of other things.
I was hoping to ask him for more details but lost the post :-(
Mathew
Vehicle: Vitara 1.6
Post Posted: Wed Jul 08, 2015 12:10 am
Okay given i had all those hits and no answers that others want to know to -)
Jdk81 said the following in may this year:
Yes it can be made to fit a SWB
You need;
to cut the fuel tank mounts off the chassis and make custom ones,
a body lift,
to move the rear shocks forwards a little,
to route the exhaust out the chassis rail,
bit of fiddling with the fuel filler.
Vehicle: Drover pickup turk
Post Posted: Wed Jul 08, 2015 12:23 am
JDK's comments you're quoting are for a LWB Vit tank into a SWB sierra. Is that what you're asking about?
When I read the title it sounded like you wanted a LWB Vit tank in a SWB Vit.
I like the tuna here
Vehicle: Vitara 1.6
Post Posted: Wed Jul 08, 2015 12:04 pm
THAT would explain it then.
Yes i am talking about vitaras. So will file it in the no possible category and sorry for getting anybody excited...
I am lookinh to upgrade my dented tank on my body lifted swb vit though
Post Posted: Wed Jul 08, 2015 6:46 pm
I would say you would need to make a new rear cross member and try and bend the lip of the tank down to make it fit. The tank lips sit under the chassis so they would need to be flat agains the tank to get it up higher between the rails .
U would need all new mounts as well.
U may need to mave the cross member in front of the tank aswell .
Post Posted: Wed Jul 08, 2015 6:51 pm
A lwb vit tank is wider, longer, and deeper, than a swb vit and it doesn't have that funny corner taken out.
The front x- member and mounts will certainly need work.
The rear may be ok.
I would give it a try.
The measurements of each tank are around the forum somewhere.
Vehicle: Vitara 1.6
Post Posted: Wed Jul 08, 2015 9:10 pm
The measurements were what i was trying to find when I came accross the other info I started this thread with. I will measure up my LWB tank and space this weekend, at any rate/.
Mathew
Users browsing this forum: Google [Bot] and 100 guests
