https://auszookers.com/forum/
vitara tire size with 2" lift
https://auszookers.com/forum/viewtopic.php?f=5&t=50611
Author:  Tyler Atkinson [ Thu Jul 23, 2015 7:15 pm ]
Post subject:  vitara tire size with 2" lift
Hi Guys,
My brother has just bought a 89swb vitara and it looks to have about a 2" suspension lift (sits 55mm higher then mine from centre of axel to guard)
What sized tires can he go up to comfortably without scuffing? it has 205/70/r15 on it and they look quite funny under it. Im not sure on the offset of the rims it has Bathurst Globe 15x7" on it
I have 235/75/r15 under mine on sunnies at stock height and was wondering how much bigger he can go.
Thanks
Tyler
Author:  frak [ Thu Jul 23, 2015 9:37 pm ]
Post subject:  Re: vitara tire size with 2" lift
I have a SWB vitara with the same lift. Has 31s and I need to do some chopping.
You can see it in the owners cars subforum.
Author:  just_cruizin [ Fri Jul 24, 2015 1:13 pm ]
Depends on how well the suspension works, if it works well the fit won't provide any additional clearance and if fact should reduce tyre clearances. If it's crap probably 30's fit with no scrubbing.
Author:  DENTED [ Sun Jul 26, 2015 5:19 am ]
Just fitted 30s on a swb Vitara on 15x7 -13 and doesn't scrub
Author:  frak [ Tue Jul 28, 2015 11:10 pm ]
Just to clear up... i read u saying body lift so ignore my comment above!
Sent from my SM-G900I using Tapatalk
