It is currently Sat Oct 24, 2026 2:40 pm
Vehicle: 89 swb sj50 widetrack
Post Posted: Sat Jul 25, 2015 5:20 pm
trying to remove my alt but dosn,t seem to have a bolt at the bottom rather it seems to have a pressed pin and like a cradel bolted to the block instead.It is loose so need to fix.any help appreciated
Post Posted: Sat Jul 25, 2015 5:54 pm
Should be two bolts on the bottom.
The nuts are easy to access with a 12mm spanner. One front, one back.
Can get very good/easy access from under car with plastic cowl removed, or from the top with airbox removed.
Post Posted: Sat Jul 25, 2015 6:09 pm
there defiantly are no bolts underneath .looks like its in a cradle.of some sort.it is all factory as have had for 22 years and has never had new alternator
Post Posted: Sat Jul 25, 2015 8:41 pm
ok so found why it looks like a pin the bolt heads had sheard off.problem solved.thanks for advise
Users browsing this forum: Google [Bot] and 91 guests
