It is currently Mon Oct 19, 2026 8:22 am
Post new topic Reply to topic  [ 43 posts ]  Go to page 1, 2  Next
Post Posted: Mon Nov 20, 2006 1:05 am
HOLY CRAP 8O the zuk has a mind of its own. im getting reallg bad death wobbles in my zook it happens at about 40kmh-50kmh i can sometimes accelerate out of it, but i usually have to pull over i put a 2 inch lift in it last night. yes everything is tight.
Help please
Post Posted: Mon Nov 20, 2006 1:24 am
your swivel hub seals are worn
your king pins may not be at correct pre load
your steering stabiliser may be loose / broken
your u bolts may be loose
the lift doesnt cause it, its the weight of the springs and stiffness of the bushes that move the harmonic point of the wobble into the driving range
Post Posted: Mon Nov 20, 2006 2:06 am
Wow if all that is wrong then shoot :rambo: it before it spreads through the forum
Steve W
Post Posted: Mon Nov 20, 2006 2:15 am
only needs to be 1 thing from that list
score one for vits, no death wobbles :wink:
Post Posted: Mon Nov 20, 2006 2:26 am
the front springs could be rooted,mine where and i got huge death vibe's through mine
Post Posted: Mon Nov 20, 2006 3:32 am
they are barnd new i only pickred them up for the shop yesturday
Post Posted: Mon Nov 20, 2006 12:25 pm
did u undo the steering at all
[img]http://www.nbs4x4club.com/forum/files/thumbs/
Post Posted: Mon Nov 20, 2006 2:02 pm
nope didnt touch the steering at all.
Post Posted: Mon Nov 20, 2006 2:04 pm
I am with you Royce. Vit's RULE
Steve W
Vehicle: 75 Cruiser
Post Posted: Mon Nov 20, 2006 3:09 pm
worn wheel bearings could also contribute.
I've had this problem with all my zooks... ahh the fun.
make sure ya got good or new bushes, a good steering dampner, and check ya wheel bearings.
Post Posted: Mon Nov 20, 2006 3:31 pm
i think it mite be the swivel hub seal. where are the kingpins? everything else is ok.
Post Posted: Mon Nov 20, 2006 3:38 pm
kingpins are the bearings the hubs steer on, they are under the caps on the swivels
cant remember the specs now but its in the manual in the downloads section :wink:
Post Posted: Mon Nov 20, 2006 11:37 pm
Hey Bruce can you think of something that may need replacing in the steering
:roll: :roll: :roll: :roll: :roll:
Steve W
Post Posted: Mon Nov 20, 2006 11:43 pm
i jest redid all my bearings, didn't tension kingpins and it seems fine. are u using same tyres. could be outta balance
Post Posted: Tue Nov 21, 2006 1:08 am
yeah same wheels and tyres. extended shackles and shocks are all the same too.. only things new are springs and bushes
84 lwb sierra, 30x9.5, 2 inch lift
http://www.aus
Post Posted: Tue Nov 21, 2006 1:41 am
i just checked the steering dampner and it works great on way but when i push it in it moves about 2 1/2 inches before it gets any resistance. looks like ill be buying a new dampner tomorrow
http://www.aus
Post Posted: Tue Nov 21, 2006 1:43 am
steal ya bros to check so ya dont waist ya money cuz mines rooted with rust holes in it and i dont get wobbles
Post Posted: Tue Nov 21, 2006 2:42 am
hes down the coast other wise i would
http://www.aus
Post Posted: Tue Oct 30, 2007 5:10 pm
hey i have the same problem to, there's no play in n e of the bearing, the wheels are balanced to!
but when i put 31's on i don't get n e wobbles at all!
Post Posted: Wed Oct 31, 2007 12:42 am
TRY TAKING A SHIM OUT OF YOUR KINGPINS. WILL ADD A LITTLE PRELOAD BACK ONTO YOUR KINGPINS.THE SHIMS ARE UNDER THE KINGPIN CAPS. MY HUBBY HAD THE SAME PROBLEM AND THIS FIXED IT.
Post Posted: Wed Oct 31, 2007 7:31 pm
ok thanks
will try it
Post Posted: Sat Nov 03, 2007 4:37 pm
just wondering how u went?
Post Posted: Wed Jan 09, 2008 11:29 pm
I am in the same boat, brand new springs, got the wheels balanced and checked the bolts everywhere and they are crazy at around 60kms and sometimes you can push past them but most the time you have to stomp down to arouns 30kms and hour (pretty dangerous!) they also go away when I put my mates 30''s on there.
Any miracle cures or solutions to this problem yet????
Post Posted: Wed Jan 09, 2008 11:46 pm
my miracle cure is scraper seals, if it definatly doesnt do it with your mates 30's (at any other speed) then look at your rims and tires, difference in weight or offset can do it
or moving the steering stabiliser down onto the diff like a hilux works good too
http://www.puresuzuki.com/steering_stabilizer_kit.htm
Vehicle: 75 Cruiser
Post Posted: Thu Jan 10, 2008 1:35 am
excellent, another one with death wobbles, makes me feel better :twisted:
Post Posted: Thu Jan 10, 2008 2:01 am
You say you have new springs , this would of changed your kingpin angle if they are lifted springs , also your kingpin bearings , if notchy will cause it, also wider rims , plus a combination of steering box play , loose or worn drag link and ball joints , plus a worn steering dampner , I had this problem , so I moved it down to the diff and used a 80 series dampner , driving at 110 on the freeway , no vibration and steers perfectly , cheers Paul
Post Posted: Thu Jan 10, 2008 1:49 pm
oh ok,
Is moving the steering dampner to the diff a big job or an expensive one? also is the steering kit the same as the return to centre steering kit that's on ebay?
I have just bought a set of 31s but I need to fit a body lift first so can I just assume it will be right with the bigger wheels on it or will it come back to bite me on the arse later on?
Thanks
Post Posted: Wed Feb 27, 2008 4:43 am
Had the same problem in mine, this isn't so much a solution but mine were really bad at 50-70 kms and I ended up replacing the front wheel bearings and hubs and still got them, they didn't go away until I bought 4 new tyres. Had no wobbles for a few weeks but just recently they started to surface again but are very minimal. Hope this can be of some help if you are running out of solutions
Post Posted: Thu Feb 28, 2008 10:06 pm
watch that your sway bar is not jammed against your steering dampner the hangers arent long enough for a 2 inch lift.
Post Posted: Fri Feb 29, 2008 1:24 pm
Or even better, ditch the sway bar all together!! :rambo:
Users browsing this forum: No registered users and 214 guests
