https://auszookers.com/forum/
Grand vitara rear arb air locker
https://auszookers.com/forum/viewtopic.php?f=5&t=50701
Author:  2000 gv [ Mon Aug 03, 2015 6:46 pm ]
Post subject:  Grand vitara rear arb air locker
I want to put a locker in the rear of my grand vitara but I would like to not touch the front diff. Is it possible to put a vitara third member and ring and pinion with 4:3 ratio (the same as the front) in and not have any problems? Cheers
Author:  fordem [ Tue Aug 04, 2015 2:56 am ]
Post subject:  Re: Grand vitara rear arb air locker
I'm a little puzzled here - would it not be simpler to just put an RD209 in your existing rear differential?
Depending on whom you speak with, it will either bolt right in, or, you may need to machine the ring gear ID to clear the locker housing.
Author:  2000 gv [ Tue Aug 04, 2015 11:43 am ]
I didn't think there where any diff locks that fit into a stock rear gv diff?
Author:  watermouse [ Tue Aug 04, 2015 1:12 pm ]
I think its the other way around. Nothing that officially fits the GV front.
edit: ARB application guide
https://www.arb.com.au/assets/air-lockers/application_chart.pdf
Author:  watermouse [ Tue Aug 04, 2015 1:22 pm ]
Read the footnotes under the Suzuki section and make of it what you will.
Author:  2000 gv [ Tue Aug 04, 2015 3:58 pm ]
Yeah so a vitara rear third member with 4:3 gears will fit a diff lock and not effect the front at all?
Author:  watermouse [ Tue Aug 04, 2015 4:13 pm ]
As long as the ratios are the same there will be no dramas.
There are other issues with the front diffs in early GVs that relate to the 4wd engagement mechanism slipping under high differential loads. So there is some merit in getting that sorted.
But I can understand not wanting to touch the front.
Author:  2000 gv [ Tue Aug 04, 2015 4:21 pm ]
I'd love to touch the front and slap a locker in there aswell buy from what I've been reading it's a whole lot of messing around and my cars my daily so can't really have it off the road for too long
