It is currently Thu Oct 22, 2026 3:49 pm
Post Posted: Fri Aug 07, 2015 9:05 pm
Hi AZ,
I've put a baleno G16b into my sierra and I'm just trying to figure out where the best place would be to place the temp sender. The factory baleno temp sender for the ecu is still in it's original position and I've opted to use a factory g13 temp sender so it will work with the sierra temp gauge in the cluster.
I've tapped it into the thermostat housing as shown in the picture, but I just wanted to check where you guys think would be the bet place to put it in order to get the most accurate temperature reading? As I've had the car running for a while and the gauge only just creeps past the cold level.
Users browsing this forum: No registered users and 138 guests
