It is currently Thu Oct 22, 2026 2:56 pm
Vehicle: 1973 lj50 fully restored
Post Posted: Sun Aug 09, 2015 8:39 am
I have a 1litre motor with a run bearing needing crank grind and also a good crank out of a 800cc stockman motor are these crankshafts interchangable.Thanks in anticipation.
Post Posted: Sun Aug 09, 2015 10:32 am
The crank will physically fit but the stoke is 6mm shorter so you'd lose capacity and your compression ratio would be garbage.
Post Posted: Sun Aug 09, 2015 4:17 pm
Thanks for the info I really appreciate the help.
Vehicle: 1995 Vitara, SWB
Post Posted: Sun Aug 09, 2015 9:33 pm
pompoms Wow, Is there anything you don't know SIDEWAYS. Great stuff.
Post Posted: Sun Aug 09, 2015 10:18 pm
sideways wrote:
The crank will physically fit / your compression ratio would be garbage.
8) supercharged F10 Armsup
stephen
Users browsing this forum: Google [Bot] and 151 guests
