https://auszookers.com/forum/
Sierra ignition barrel
https://auszookers.com/forum/viewtopic.php?f=5&t=50812
Author:  suzukikid [ Mon Aug 17, 2015 12:05 pm ]
Post subject:  Sierra ignition barrel
I have lost misplaced my keys and have torn the joint apart!
Are any other barrels the same?
There are 4 wires going into the barrel is it as easy as 2 for accesories and 2 to start so I could just put in 2 switches?
Thanks
Author:  suzukikid [ Mon Aug 17, 2015 3:10 pm ]
Post subject:  Re: Sierra ignition barrel
Also is wt and nt the same?
Author:  Scrawny [ Mon Aug 17, 2015 3:28 pm ]
Wires should be:
-Permanent power TO switch
-Accessories power FROM switch
-Ignition power FROM switch
-Start signal FROM switch
If you jump a wire from permanent to ignition, then another from permanent to start it should fire into life.
Author:  suzukikid [ Mon Aug 17, 2015 4:25 pm ]
I think I have sourced a barrel and door locks but if it falls through I will try work out some switches and push button start!
I have heard nt and wt are different.... Is this true?
Author:  cairns27 [ Wed Aug 19, 2015 8:20 am ]
The key number is on passenger side door lock, just get one cut
Bye
Author:  suzukikid [ Wed Aug 19, 2015 4:21 pm ]
What? Haha
