It is currently Thu Oct 22, 2026 1:44 pm
Vehicle: Jimny, 2 inch lift.
Post Posted: Thu Aug 27, 2015 2:00 pm
So i need to replace my front right hand side wheel bearing on my 2008 jimny. Was just wondering if anyone has any experience with this. Also if its able to be done at home or if i would need to take it to a mechanic and how much should i be looking at forking out to get it fixed.
Gab
Vehicle: zook
Post Posted: Thu Aug 27, 2015 5:36 pm
You will need the BenT hub nut removal tool
http://www.auszookers.com/forum/viewtopic.php?f=15&t=15009
And a big torque wrench.
Other than that you don't need any special tools. Easy enough to do on jack stands in you garage.
Here is a great guide http://www.bigjimny.com/images/documents/Changing_the_Front_Wheel_Bearings.pdf
Here is an old thread that I started years ago (when I was a special tool) that covers some aspects of the hub removal and also kingpins service.
http://www.auszookers.com/forum/viewtopic.php?t=19943
There are various other threads that go over front hub bearing related maintenance if you can search for them.
Post Posted: Sun Aug 30, 2015 11:29 am
Cheers for the info :) seems simple enough, famous last words hahaha
Post Posted: Sun Aug 30, 2015 12:53 pm
It's simple if you have a torque wrench that can run to 220Nm - that's a pretty big torque wrench.
I imagine there are preload or starting torque specs for the hub once reassembled. I'd be wanting to get those figures from the FSM.
Vehicle: 2011 Jimny
Post Posted: Tue Sep 01, 2015 4:04 am
I did mine 2 weekends ago using a mallet and large sockets to push the bearing out/in.
longest part of it all was the dis-assembly of it all, 220Nm (16lb-ft) is the only figure they give you in the FSM
Vehicle: Suzuki Jimny 2009
Post Posted: Tue Sep 01, 2015 6:49 pm
That is correct the FSM specifies 220Nm.
Post Posted: Wed Sep 02, 2015 8:35 am
Cool, so far it doesn't seem like ill be able to get it fixed until next week.
Users browsing this forum: Google [Bot] and 116 guests
