I'm going to be changing my 4:3 gearing to 4:8 gearing and I just wanted to make sure that the 4:8 ring and pinion will bolt straight to the 4:3 centre? Or will I. Need 4:8 centres to fit them? Cheers
From GV (SQ) and SV The 4.8 ring will bolt to the center from the 4.3. The pinions drop in but the pinion height will need to be checked and shimmed if necessary. Same deal for either end.
