It is currently Sun Oct 25, 2026 2:18 am
Vehicle: 95 maruti trayback
Post Posted: Tue Sep 01, 2015 3:20 pm
I'm going to be changing my 4:3 gearing to 4:8 gearing and I just wanted to make sure that the 4:8 ring and pinion will bolt straight to the 4:3 centre? Or will I. Need 4:8 centres to fit them? Cheers
Vehicle: zook
Post Posted: Tue Sep 01, 2015 8:47 pm
From GV (SQ) and SV The 4.8 ring will bolt to the center from the 4.3. The pinions drop in but the pinion height will need to be checked and shimmed if necessary. Same deal for either end.
The only exception are diffs from the rear of an XL7 as they are physically larger (not sure on ratio so may not be an issue for you. 4.3/5.12? http://www.auszookers.com/forum/viewtopic.php?f=17&t=44910)
Post Posted: Wed Sep 02, 2015 9:18 am
So if I was to take my diff and the new gears to a diff shop they would be able to sort that all out for me?
Vehicle: zook
Post Posted: Wed Sep 02, 2015 12:14 pm
Yes. A good diff shop will be able to do that for you.
You may want to put a call out for recommended diff workshops in WA that other Auszookers have used.
Users browsing this forum: Google Adsense [Bot] and 115 guests
