Joined: Mon Nov 05, 2012 9:19 am Posts: 101 Location: Darwin
Vehicle: 99 jimny
Posted: Thu Sep 03, 2015 7:52 pm
How much lift do you need before you need adjustable panhard rods? I was thinking that 40mm lift wouldn't be enough to need it but if I went 80mm then it would. Does that sound right?
Depends on how much you value a centered diff housing. My 2inch lifted Jimny pushed the rear end across about 15mm which was noticable and bugged me initially. I put up with it however.
I have a 40mm lift and I would say it is not that bad with this amount. For an 80mm lift I agree you would need some adjustment. I have adjustable rods but these were replaced due to them being stronger.
Adjustable panhard rods only solve part of the problem - centering the axle - a relocation bracket is a much better solution, it reduces "rear end bump steer" - the sideways movement of the axle as it articulates.
Users browsing this forum: Google [Bot], phlix and 126 guests
