It is currently Sat Oct 24, 2026 7:28 pm
Vehicle: '99 Suzuki Grand Vitara V6
Post Posted: Wed Sep 02, 2015 5:50 pm
Evening all, had a browse of the forums but can't find anything as I can't be specific enough with my searches.
Majority of the time, when I go to put the zook into revers, it's as if the gear were spinning forward already, (even if I've just started the car) and I have to hold the gear stick down into reverse, until the 'gear' slows to a stop, then engages.. Issue seems to be even worse when I'm in low 4. Is there a fix? Something wrong?
Hoping it's not a clutch issue, but the dealer that I bought the car from gave me $500 warranty on the clutch for a few years.
Cheers, Sam. :beer:
Post Posted: Wed Sep 02, 2015 5:54 pm
From what I'm reading on google, it may not be an issue, but it just seems to be a little excessive for 'something that just happens'.
Vehicle: Suzuki Jimny
Post Posted: Wed Sep 02, 2015 6:16 pm
My jimny grinds into reverse when rolling forward at all and will sometimes not engage until I start to release the clutch, just a normal thing for most manuals I am told
Post Posted: Wed Sep 02, 2015 6:27 pm
Hmm, yeah I'm reading similar things, oh well, thankyou!
Post Posted: Wed Sep 02, 2015 9:30 pm
The clutch might need adjusting, would try that first. Shouldnt need to slow down the gears by using force. (Holding gear stick in R position) it should go relatively easy/quick
Post Posted: Wed Sep 02, 2015 9:36 pm
How would I go about adjusting the clutch? I assume there would be a guide or something along those lines somewhere here?
Vehicle: zook
Post Posted: Wed Sep 02, 2015 9:58 pm
For hydraulic actuated clutches this is a symptom of a worn clutch as hydraulic clutches are self adjusting.
Could also be a seized/draggy spigot bearing in the flywheel giving the input shaft a bit of spin even with the clutch in.
There is no synchromesh on reverse gear
If the car is rolling forward at all it will always be crunchy.
https://en.wikipedia.org/wiki/Manual_transmission#Reverse
Post Posted: Thu Sep 03, 2015 5:20 am
The clutch cable can be adjusted. The saddle nut on my serria somehow comes loose over a year, and a few winds by hand, all good for another year,,,
bye
Post Posted: Thu Sep 03, 2015 5:56 am
At what point in the clutch travel does the clutch "take up" - near the floor? Is it also difficult to select first gear from a standstill (not necessarily grinding) or downshifting (third to second)?
On the GV a worn clutch will cause the grinding into reverse, along with the other symptoms mentioned above - other than that clutch drag, either because of a binding pilot shaft bearing, contaminated clutch linings or a clutch disk binding on the splines.
Anyway you twist & turn it, it sounds like the box has to come out.
Vehicle: 1991 vitara soft top jlx
Post Posted: Thu Sep 03, 2015 11:48 am
Make sure ya not moving when you shift to reverse, put it into first then straight to reverse. Give that a shot
Users browsing this forum: No registered users and 148 guests
