It is currently Thu Oct 22, 2026 6:07 pm
Vehicle: 92 Sierra SJ70
Post Posted: Wed Sep 02, 2015 9:45 pm
I have a 92 sierra sj70 with a g13ba. The 5 speed seems to be leaking oil and it's soaking the rear transmission mount. It seems like it could be the output shaft seal. Although I read it is dry in the rear case. Where else should I be checking? It is transmission fluid for sure.
Do i need to remove the transmission to be able to troubleshoot this? I checked out the FSM but it looks like a little bit of work if i have to get the transmission out.
I'm going to have to pull it out aren't I? :roll:
Vehicle: Drover pickup turk
Post Posted: Wed Sep 02, 2015 11:17 pm
Gearbox output seal can be done with the box in the car still. May have to unbolt Tcase to move it over slightly to get jackshaft out.
I like the tuna here
Vehicle: Maruti Trayback
Post Posted: Thu Sep 03, 2015 11:48 am
If you do have to remove transmission it isnt that hard if you put a notch in the crossmember to drop it down.
Vehicle: 1993 Sierra 1.6 efi Vit motor,
Post Posted: Tue Sep 08, 2015 6:34 pm
Overfilling the gearbox will cause it to leak as well.
Users browsing this forum: No registered users and 111 guests
