It is currently Thu Oct 22, 2026 6:23 pm
Vehicle: 99 jimny
Post Posted: Thu Sep 03, 2015 7:52 pm
How much lift do you need before you need adjustable panhard rods?
I was thinking that 40mm lift wouldn't be enough to need it but if I went 80mm then it would.
Does that sound right?
Vehicle: zook
Post Posted: Thu Sep 03, 2015 8:38 pm
Depends on how much you value a centered diff housing.
My 2inch lifted Jimny pushed the rear end across about 15mm which was noticable and bugged me initially. I put up with it however.
Vehicle: Suzuki Jimny 2009
Post Posted: Thu Sep 03, 2015 9:24 pm
I have a 40mm lift and I would say it is not that bad with this amount. For an 80mm lift I agree you would need some adjustment. I have adjustable rods but these were replaced due to them being stronger.
Post Posted: Thu Sep 03, 2015 11:12 pm
Adjustable panhard rods only solve part of the problem - centering the axle - a relocation bracket is a much better solution, it reduces "rear end bump steer" - the sideways movement of the axle as it articulates.
Post Posted: Fri Sep 04, 2015 6:17 am
Relocation bracket plus drop pitman arm. If u only do one u will have bump steer
Users browsing this forum: Google [Bot] and 70 guests
