It is currently Thu Oct 22, 2026 1:17 am
Vehicle: Looking to buy a Suzuki Jimny
Post Posted: Sat Nov 14, 2015 1:18 pm
Hey guys on my 2015 Jimny I'm running 215/75r15 AT's on stock suspension and stock rims. I haven't experienced any scrubbing so far, but if I wanted to add a bull bar, is the extra weight going to cause scrubbing if I don't lift it? Any one running bigger tyres on stock suspension with a bull bar?
I'm looking at the Outback Accessories commercial bar.
Post Posted: Tue Nov 24, 2015 8:46 pm
Can anyone assist with this query? Cheers
Post Posted: Tue Nov 24, 2015 9:36 pm
No. It won't.
Vehicle: Vitara 1994
Post Posted: Tue Nov 24, 2015 11:13 pm
No reason it should as if it's not rubbing now as it cycles through the suspension, even if it does sit lower with the bar it won't rub.
Also the front bar is the limiting factor clearance wise on a jimny so you should in therory gain clearance
Post Posted: Wed Nov 25, 2015 5:49 am
That's great thanks guys
Platinum Supporter
Platinum Supporter
Vehicle: 2010 jimny
Post Posted: Wed Nov 25, 2015 8:33 am
you will get worse fuel evonomy with a bullbar FYI.
Vehicle: LWB Sierra & XL7
Post Posted: Sat Dec 05, 2015 9:31 am
225/75 Tyres
The 2"lift in the front has sagged to 5mm above standard height, still no scrubbing with ARB steel bar with winch.
'92 Vitara & Camper trailer
Post Posted: Sat Dec 05, 2015 10:32 am
I wonder if it will sag too much with stock no lift and be too low
Vehicle: 98 Jimny
Post Posted: Sun Dec 06, 2015 7:31 am
You can always add coil spacers to get the height back if your worried about sag.
Users browsing this forum: No registered users and 184 guests
