It is currently Thu Oct 22, 2026 1:17 am
Vehicle: sj70 1996 sierra
Post Posted: Sat Nov 28, 2015 8:09 pm
G'day everyone, im just wondering if anyone can tell where else does engine oil leak from between the gear box and engine, i thought is was the rear main seal, got that replaced and its still leaking. Any other seals that leak oil around that area? Cheers
Vehicle: Coily.
Post Posted: Sat Nov 28, 2015 8:24 pm
Yeah,distributer housing,new o ring and sealant needed.Many Mechanics mis-diagnose leak as a rear main seal.
Post Posted: Sat Nov 28, 2015 10:04 pm
Distributor shaft /body to housing o-ring is the most likely, as above, but even the rocker cover can dribble a bit down the back, as wind flow over the engine, pushes the oil rearward.
Really need to degrease well, including the back of the engine (spray cans of brake cleaner are effective) take the car for a drive/s, use a small mirror on a stick if you need to, until you see the start of a wetness trail.
Could still be the rear main seal, if it got nicked or put in crooked, or if the surface it runs on has a groove in it.
Good luck, Rgs Michael
Post Posted: Sun Nov 29, 2015 7:46 am
cheers for the help fellas ill give her a good clean and have a good look
Vehicle: Coily.
Post Posted: Sun Nov 29, 2015 8:27 am
....before you clean it all up do the Dizzy. O ring first,they all harden and fail eventually,just be careful that you note the position of the rotor when you remove dizzy so you don't lose your timing.
There is a thread on here somewhere showing a step by step on replacing O ring,i think they use red RTV as the sealant.
Post Posted: Thu Dec 03, 2015 3:08 pm
cheers for the info guys, i got the o ring for the Dizzy replaced and its all good in the hood haha
