Vehicle: suzuki sierra
Posted: Thu Dec 17, 2015 8:39 pm
hi are all the chassis of the sj70/sj413 the same even though they come with different motors because i have got a 1996 leafy sj70 hard top with a g13ba motor and was wondering if an sj413 with a g13a chassis will fit?
Posted: Fri Dec 18, 2015 3:35 pm
thanks for quick reply and are the engine parts interchangeable? like distributor, exhaust manifold, heads and intake manifold i know the crank from the g13a doesn't fit but want to make sure because i want to install a fwd g13ba 1298cc into my suzi and wanted to know if i can swap parts over from a wrecked g13a 1324cc engine to convert it to a rwd and i can't find an answer its all just copy and paste the same things over and over on the net did a read around and found out that there's a difference between flywheels in the g13a and g13ba so i'm assuming you can't swap gearboxes around ones stepped the other isn't just flat
Users browsing this forum: Google [Bot], phlix and 133 guests
