It is currently Sat Oct 24, 2026 1:22 am
Post new topic Reply to topic  [ 44 posts ]  Go to page 1, 2  Next
Post Posted: Mon Nov 23, 2015 1:52 pm
So it looks like i've done a head gasket (or in the early stages of) - which is the second in about 1.5 years. There's gotta be something wrong with my block (head's been checked many times).
As i see it i've got a few options that keep the power i'm used to, all varying in cost:
1) Fix the gasket and hope it doesnt happen again..again
2) Drop in a reco'd 1.6 bottom end
3) Do away with the ageing G-series platform and go for an M15 conversion
Unless there's another option?
Keep in mind my sierra in engineered for a 1.6L engine, so I do need to keep the capacity about the same. VSB14 means you can't chuck a 1.8 in without brake tests and all that junk so that's out of the question.
...Go!
Post Posted: Mon Nov 23, 2015 1:56 pm
Chuck a low km baleno motor in
Post Posted: Mon Nov 23, 2015 1:58 pm
Id rather suzuki built with 100,000+ kms on it than a recon
Post Posted: Mon Nov 23, 2015 2:24 pm
Given that yours is all engineered I'd agree with a Baleno engine
Post Posted: Mon Nov 23, 2015 2:49 pm
Out of curiosity - why opt for a g16 over an m15?
Post Posted: Mon Nov 23, 2015 2:54 pm
Compatibility to everything you already have? You can just drop another long block in there and drive away in a weekend.
Post Posted: Mon Nov 23, 2015 2:57 pm
M15 would be a nightmare by comparison - new loom, ECU, immobiliser (?) 1/2 a Jimny manual, tailshaft housing swap, source Jimny sump, oil pickup, engine mounts, extractors, and a million other little things.
Just find a low KM baleno.
Post Posted: Mon Nov 23, 2015 4:10 pm
Sourcing parts is easy and Suzistore would be doing the swap. They have stock of low km wrecks to pull parts from.
I'm coming entirely from the point of view of reliability and driveability - putting cost aside, how would the m15 compare to the baleno assuming both are from low-km wrecks?
I've not driven an M15'd sierra so i don't know the difference i'd FEEL - but given m15 are going to be far more common that g16's and newer, surely by doing that work up front would result in a more future-proof engine setup that's going to have less issues than the ageing G16?
Vehicle: Vitara 1994
Post Posted: Tue Nov 24, 2015 2:32 am
I doubt it. From a cost perspective the g16 will be the more reliable of the two.
Just get your block decked and call it a day
Post Posted: Tue Nov 24, 2015 3:19 am
If cost is not a problem, newer can be a good thing.
If somebody else is doing the work and maintenance, their way could be best?
But my choice would leave well enough alone in todays legal nightmare.
G16 low K imported engines are cheap, reliable and have a fair warrantee.
Paying to fix a gasket properly ain't cheap, and would be unwise without freshening up the bottom end.
When my Vit donk carked it, I fitted an import Baleno/swift efi G16A,
using the bits from the dead donk to convert to rear drive/North South.
It has been going well for years and many trips, including towing on beach and outback trips.
G16's out of east west cars can be 5 years or so newer than Vit donks.
PS I'm not a mechanic, don't have experiences at everything, so is just my opinions.
Post Posted: Tue Nov 24, 2015 5:54 am
I'm yet to see a G motor that's been apart last.
I don't know if it's a result of poor rebuilds or that these motors just aren't designed to be rebuilt, but it's what I've observed over the years.
Post Posted: Tue Nov 24, 2015 6:40 am
Having recently driven an m15 sierra (possibly the only one in wa)
And plenty of g16 sierras i like the feel of the g16 its a bit crisper on delivery.
Considering the price of a low km baleno motor even though m15sare cheap as well id still go the g16. Ive done over 60,000kms of unfriendly driving on mine taking it up to about 250xxx on the motor and had not one issue, same as the last one i had which id done 90xxx + kms on.
I can possibly tee up a test drive of the m15 sierra for you to compare
Flick us a msg 0437154527
Post Posted: Tue Nov 24, 2015 7:39 am
Thanks guys, more and more keeping g16 is seeming appealing.
Mick - bit of looking around online and the feel might be due to g16 hitting peak torque about 1000rpm sooner than m15?
Post Posted: Tue Nov 24, 2015 8:29 am
Yeah and when they have lots of gearing at extended higher rpm my mates one goes into limp mode and u have to tape the key in the m15 ignition and shove it under the dash cause u cant bypass it.
I remember sean trying to do it for ages on my mates one that suzistore built
Post Posted: Tue Nov 24, 2015 11:25 am
hahaah yeah i remember him pulling his hair out over it too =)
Post Posted: Tue Nov 24, 2015 6:49 pm
j20 and auto, Lowrange have engine mounts and after the vitara transfer has been tossed away it's easy enough
to mod a jack shaft to keep the sierra transfer.
Post Posted: Tue Nov 24, 2015 11:20 pm
j20 would require brake upgrades, engineering etc, so is a no go.
Post Posted: Wed Nov 25, 2015 2:46 am
Why not M16a?
Swift sports 100kw? or the new 'Vitara' has them although detuned, unsure why, Maybe for fuel economy
The Jim i wrecked out years ago ws a smoooooth motor but a slug with auto. M13a.
There's heaps of cheap Balenos out there. Find a smashed 98+ model and bobs your aunty for <$500
Post Posted: Wed Nov 25, 2015 7:36 am
I didn't realise the m16 was available outside the swift sport so suggested the m15 due to being more common, plus the 15's power output matches the g16.
Fair idea though!
Post Posted: Thu Nov 26, 2015 7:40 am
The APV van thing still runs a version of G16 - North / South configuration (although bound to be lots of bits that will have to come from a donor Vit eng, as it's on a bit of an angle in the APV I belive) & still made new - that's where I'd look for a replacement for your current eng. Rgs, Michael
Post Posted: Thu Nov 26, 2015 8:41 am
Not jap built though i believe ?
Post Posted: Thu Nov 26, 2015 11:36 am
Made in indonesia, well, assembled.. not sure if the castings are done in indonesia?
Post Posted: Thu Nov 26, 2015 11:46 am
Low km baleno block from the dizzy models are cheap as chips
Factory built is best
Vehicle: sj51
Post Posted: Thu Nov 26, 2015 1:34 pm
Id just run a coil pack baleno.. simple and cheap
I'm back..... Again
Post Posted: Thu Nov 26, 2015 1:53 pm
With a jimny inlet manifold to retain the water neck.
Platinum Supporter
Platinum Supporter
Vehicle: 2010 jimny
Post Posted: Thu Nov 26, 2015 2:52 pm
electric 20kw motor with lithium batteries, if moolah wasn't a issue.
Vehicle: Snowman the '03 Grand Vitara
Post Posted: Thu Nov 26, 2015 8:12 pm
G16B in my Sierra coily was wonderful to drive. All professionally installed by a mechanic (previous owner), it looked like it belonged in there. Servicing it was a breeze!
Post Posted: Thu Nov 26, 2015 8:36 pm
Hes already got that stuff on current setup
Just needs bottom end essentially
Post Posted: Thu Nov 26, 2015 10:34 pm
Correct.
Mines got a jimny head on it though.
Users browsing this forum: Google [Bot] and 108 guests
