It is currently Thu Jul 30, 2026 1:46 pm
Post Posted: Mon Jan 05, 2009 9:26 pm
Hey guys, does anyone have a bigger/better radiator in their sierra? does anyone know if the vitara one is a bolt in?
mine gets a bit warm when im lowranging and im looking to install lower gears and a 1.6 so im looking to put in somthing bigger
options?
Post Posted: Mon Jan 05, 2009 9:27 pm
Yes a vitara one will fit. Just wait till Royce gets on a little later as he did a Vitara setup when he had his Sierra.
Post Posted: Mon Jan 05, 2009 9:39 pm
youll need a bodylift and some new brackets but pretty straight forward
vit clutch fan is also a simple mod
vitara 1.6 rads are not a bolt in fit but are muche better. if you are able to cut and or remove all the vit mounting items you can adapt it to a sierra, or fab from scratch. if you intend to go power steer than measure up the box you will use as this will affect where you might place the radiator.
all the 1.6 egines i do i will use a vit radiator. i won't warranty anything on the engine if the customer uses the original 1.3 radiator.
Post Posted: Tue Jan 06, 2009 11:40 pm
cheers guys :)
85 NT, SPOA, 2" BL, sliders, f&r lockers, bull bar
Post Posted: Wed Jan 07, 2009 3:10 pm
Did all Vit radiators come with plastic tanks?
Post Posted: Wed Jan 07, 2009 7:36 pm
yep.
Post Posted: Wed Feb 18, 2009 11:05 pm
im looking in a radiator catalog now and their's two listing on vitara radiators listed. both pretty much the same but one the core hight is 377mm and the other 425mm wich one is the one i want to use in my sierra??
Post Posted: Thu Feb 19, 2009 12:02 am
the smaller one will be fine, but if you have a body lift you may be able to fit the larger one.
Post Posted: Thu Feb 19, 2009 1:09 am
Why is there a big one and a small one? What donors do they come from?
Post Posted: Thu Feb 19, 2009 3:35 am
cool thanks joe. i measured mine when i got home and figured it would be the small one as i have no body lift and their wouldnt be enough room for the taller one.
dont know why theirs two sizes damo both have the same listings in the book just differant height.
Vehicle: Suzuki Samurai
Post Posted: Tue Jul 29, 2014 8:28 am
Hi joe! I was wondering if you can post some pics of the mounting system. I'm trying to fit the vitara rad into the samurai, but im not getting any idea on how to mount it.
Thanks
Users browsing this forum: Google [Bot] and 285 guests
