So im trying to wire up my LED Light Bar on my 99 Jimny to be switched with my high beams. Im using an ARB rocker switch which I want to be able to use to toggle ON and OFF to allow the lightbar to work
im having a problem where my rocker switch picture LED is permanently illuminated (when the cars off) I only want it to be illuminated once my lights are switched on
I have a friend who is having the same problem with his Hilux... im thinking this is due to the fact that both the cars are negatively switched
Im just wondering if anyone has got a setup like this, or someone has a wiring diagram specific to the setup I have
Users browsing this forum: Google [Bot] and 157 guests
