Page 1 of 1
[ 6 posts ] |
Print view
Previous topic | Next topic
| Author |
Message |
Cricket99
Vehicle: 99 Suzuki Jimny
 Posted: Sun Feb 14, 2016 3:00 pm |
Hi all,
I own a 2000 jimny with a g16b manual
Recently my car has started stalling after about 10-15 minutes of driving The rev taco goes absolutely mental flickering, car starts backfiring and popping and coughing and then will eventually stall
The car then wont start for about 5 minutes, and then starts and drives for another 10-15 minutes
I have changed CAM sensor, changed a blocked/leaking injector and also swapped out ecu
Need this fixed a.s.a.p as this car is my daily
Any help is greatly appreciated,
Cheers, Daniel
watermouse
Vehicle: zook
 Posted: Sun Feb 14, 2016 7:17 pm |
Did you change the sensor with a new one? might pay to pull the housing off the back to check the cam sensor wheel flags that they are not damaged.
Also check for excessive oil in the housing and give it a good wipe out. I am not certain oil is actually a problem but cruddy oil can build up in the the sensor housing and may cause an issue.
Aside from that start looking for fueling issues, fuel pressure regulator, vacuum leaks and fuel pump.
Jezza86
Platinum Supporter
Joined: Tue Dec 06, 2011 9:30 am Posts: 2155 Location: Nhulunbuy 0880
Vehicle: 2010 jimny
 Posted: Sun Feb 14, 2016 9:21 pm |
crank angle sensor
_________________ your daily dose of questionable sanity
watermouse
Vehicle: zook
 Posted: Mon Feb 15, 2016 6:35 am |
g16b Crank angle sensor should be redundant in the jimny if you are running the jimny ecu.
Cricket99
 Posted: Thu Feb 18, 2016 1:54 pm |
The CAM sensor was brand new from suzuki, and have checked for vaccuum leaks but could not see any
Where can i locate the fuel pump and fuel filter?
watermouse
Vehicle: zook
 Posted: Thu Feb 18, 2016 6:58 pm |
Fuel pump and filter is in the tank.
Do you have the full service manual?
Page 1 of 1
[ 6 posts ] |
Users browsing this forum: Google [Bot] and 126 guests
