As the title suggests I have a F10a that, when the temp gauge shows half motor runs great at highway speed (for a 1 litre), but occasionally the temp will be slightly lower than half and it seems to lack power any suggestions? if the thermostats is no good could this effect power? Thanks
Vehicle: 98 Suzuki Stockman/maruti gyps
Posted: Sun Mar 20, 2016 10:43 pm
It seems running the little motor on the highway calls for high revs, leading a lot of air through the radiator from the fan. Which leads to a cooler running temp. Unfortunately I wouldn't know any solutions to fix the "problem", perhaps replacing the sump oil with a more viscous type, so that the oil isn't causing resistance from being colder.
Users browsing this forum: No registered users and 118 guests
