| Running cold lack of power? https://auszookers.com/forum/viewtopic.php?f=5&t=51959 |
| Author: | doity [ Wed Feb 17, 2016 5:10 pm ] |
| Post subject: | Running cold lack of power? |
As the title suggests I have a F10a that, when the temp gauge shows half motor runs great at highway speed (for a 1 litre), but occasionally the temp will be slightly lower than half and it seems to lack power any suggestions? if the thermostats is no good could this effect power? Thanks |
| Author: | Ozooker [ Sun Mar 20, 2016 10:43 pm ] |
| Post subject: | Re: Running cold lack of power? |
It seems running the little motor on the highway calls for high revs, leading a lot of air through the radiator from the fan. Which leads to a cooler running temp. Unfortunately I wouldn't know any solutions to fix the "problem", perhaps replacing the sump oil with a more viscous type, so that the oil isn't causing resistance from being colder. |
| Author: | Gwagensteve [ Mon Mar 21, 2016 6:22 am ] |
I bet someone has pulled the thermostat out at some stage. If the car starts to run cold the thermostat should close and maintain temperature. Start with the thermostat. |
