| Sierra transfer case into Jimny https://auszookers.com/forum/viewtopic.php?f=5&t=51968 |
| Author: | SSDD [ Thu Feb 18, 2016 5:13 pm ] |
| Post subject: | Sierra transfer case into Jimny |
Hi .....lurker now member Chasing a bit of advice, Looking to put a 1994 sierra transfer case onto a 2004 Jimny that has chain slip issues. After reading posts and gear ratio options on here is way over my head..I will try to put forward all the info I can From what I was told my Jimny has a 2 inch lift Current tyres are 255/70/15 that need replacing soon.(allready rub at times) Thinking perhaps 235 65 15. Transfer case I have in mind is from a 1994 Sierra and has the selector light wires on the side. My questions are.... Will it bolt straight in? Will the standard gear ratios be ok for 90% highway use? (Currently 3500 rpm at 100ks)...GPS and in car tacho Is ia 94 Sierra transfer case the geared type (not belt) ? Any other advice is welcomed Cheers |
| Author: | sideways [ Sun Feb 21, 2016 9:00 am ] |
| Post subject: | Re: Sierra transfer case into Jimny |
SSDD wrote: Hi .....lurker now member
Chasing a bit of advice, Looking to put a 1994 sierra transfer case onto a 2004 Jimny that has chain slip issues. After reading posts and gear ratio options on here is way over my head..I will try to put forward all the info I can From what I was told my Jimny has a 2 inch lift Current tyres are 255/70/15 that need replacing soon.(allready rub at times) Thinking perhaps 235 65 15. Transfer case I have in mind is from a 1994 Sierra and has the selector light wires on the side. My questions are.... Will it bolt straight in? No, you need to buy a kit + a sierra front tailshaft Will the standard gear ratios be ok for 90% highway use? (Currently 3500 rpm at 100ks)...GPS and in car tachoyes if it's a manual. No if it's an auto. Is ia 94 Sierra transfer case the geared type (not belt) ?yes. 96+ (coil sprung) sierra has a chain Any other advice is welcomed Cheers |
| Author: | SSDD [ Sun Feb 21, 2016 12:38 pm ] |
Hi Thanks for the reply. I bought the transfer case the other day ..tried for the tail shaft but it was allready gone. yes its a manual What kit should I buy? Cheers |
| Author: | russty_2008 [ Tue Feb 23, 2016 9:19 pm ] |
Hey mate I've put one in my 99 Jimny you will need a kit I used bents kit comes with instructions you will need a drive shaft spacer as Well as a Sierra drive shaft can't remember wich one tho sorry. as for gearing I can't help I bought a Sierra transfer case with 4.1 gears in it and doesn't get over 80 now but low range is amazing maybe even a tad low it's not my daily so don't care too much I drive it prety hard and destroyed 2 Jimny chain driven cases in no time but haven't had a problem with the Sierra case any other questions send me a pm mate |
| Author: | 31zook [ Wed Feb 24, 2016 2:57 pm ] |
Its an M series motor, so you will need an M-non VVT gear box for it otgerwise the gearing will be heaps out. Jimnys use an elec speedo, so you will need some sort of ring to give it signal. A WT front and jack shaft are the ones you need to buy. Other then buying the kit for fitting it from the UK you will need to modify a sierra Tcase stick to fit the new hole. Once you get the right gear box 4.16 gears or a 1L switched tcase will be perfect for the general duties |
