| Steering wheel shake https://auszookers.com/forum/viewtopic.php?f=5&t=52106 |
| Author: | Stalksy88 [ Thu Mar 10, 2016 10:40 pm ] |
| Post subject: | Steering wheel shake |
Hey guys, I noticed today that my steering wheel is shaking a fair bit while driving between 60/80 clicks.. Wasnt doing it before though Any ideas? I tried uploading a video but it wont let me.. Sent from my SM-G900I using Tapatalk |
| Author: | frak [ Thu Mar 10, 2016 11:43 pm ] |
| Post subject: | Re: Steering wheel shake |
Usually wheel balance is the reason. |
| Author: | Gwagensteve [ Fri Mar 11, 2016 9:45 am ] |
If it's very heavy it's from loose kingpins and worn knuckle seals. The trigger could be any number of things but the root cause is always the same. |
| Author: | ozzycouch [ Fri Mar 11, 2016 10:13 am ] |
Mud packed into the wheels gives mine the wobbles after wheeling... |
| Author: | Stalksy88 [ Fri Mar 11, 2016 10:33 am ] |
Cheers guys, ill suss it out Sent from my SM-G900I using Tapatalk |
| Author: | fordem [ Fri Mar 11, 2016 10:36 am ] |
It helps if you tell us which vehicle it is - or should we just assume it's the Vitara estate in your profile? Given the fact that it shows up at a particular speed, out of balance wheels is the most likely cause, but it would not hurt to go over the entire steering linkage and check the joints for looseness, that by the way includes the ball joints. |
| Author: | Gwagensteve [ Fri Mar 11, 2016 12:13 pm ] |
Oh, if it's a Vitara its going to be due to an out of round or balance rim or tyre. |
