It is currently Thu Oct 22, 2026 11:15 pm
Vehicle: Sj70 Softtop :)
Post Posted: Sun Mar 20, 2016 3:53 pm
Having issues with my g13ba zook idlling. Car starts and idles when cranked over 95 percent of the time but issues comes when i begin to drive.
Drives like a dream when in gear but as soon as I take the car out of gear and stop revving the motor the car stalls. I then have to stop and repeat the procedure (lots of left foot braking lol).
Checked the compression and timing and all is perfect but I did find something and not sure if its causing my issue. The vacuum line going to the vacuum advance on the distributor is not sucking anything at all?
Could the vacuum advance not working be a possible problem?
Thanks in advance.
Vehicle: 89 suzuki sierra
Post Posted: Sun Mar 20, 2016 4:39 pm
I had the same issue in mine a while ago. I found that one if the plugs that run to the coil had some sand in it and wasn't a big fan of that. Re plugged and cleaned everything and blew out the distributor and all was good after that.. That's what worked for me at least
Post Posted: Sun Mar 20, 2016 5:02 pm
Ill give that a go! anything to get the zook back on the road and running good!
Users browsing this forum: No registered users and 149 guests
