It is currently Tue Oct 20, 2026 2:55 pm
Vehicle: Sold zuk got a Bt50
Post Posted: Fri Jun 19, 2009 5:32 pm
Hey guys
I have a 99 GV V6 and on the down shift to 2nd gear and even sometimes high revs up shift to 2nd and 3rd
its like the noise you make when you try and put the car into reverse and your still rolling forward that little bit (teeth grinding)
and yes the cluch pedal is flat to the floor when changing gears
whould anyone have any ideas what the problem is ????
Peter
Post Posted: Fri Jun 19, 2009 5:34 pm
and should have said it dose not make the noise on the down shift to 2nd when going really slow
Post Posted: Fri Jun 19, 2009 5:50 pm
Where does the clutch pedal take off? High or low? Does the clutch slip?
Could be worn syncro's in the gearbox. Or maybe the clutch needs adjusting?
I would suggest changing the gearbox oil and putting an additive in. If that doesn't fix it you'll need to go further.
Post Posted: Fri Jun 19, 2009 5:53 pm
Most likely a worn or cracked synchro ring.
Vehicle: 75 Cruiser
Post Posted: Fri Jun 19, 2009 6:10 pm
same thing happens when you have no oil in the gearbox :oops:
Vehicle: jimny
Post Posted: Fri Jun 19, 2009 6:25 pm
my hilux has just started to do the same thing, my first thought is to bleed the clutch slave cylinder and then after that drop the oil in the box and look for broken bits
Post Posted: Fri Jun 19, 2009 6:35 pm
my sierra has been doing the same for a while. i drained the oil but there
were no bits so i put 2 tubes of sincro's in a tube in the box along
with some 85/140 gear oil.
as a result off doing this i can comfortably say don't do what i did as it made it worse. :roll:
Post Posted: Fri Jun 19, 2009 7:43 pm
how much would it be to repllace the syncro's in the gearbox ??
and the cluch takes off towards the top and no no cluch slipping
Post Posted: Fri Jun 19, 2009 8:06 pm
might be a long shot but chuck some new oil in the box. the grinding is the syncro's but new oil will help a little
Post Posted: Sat Jun 20, 2009 12:16 pm
beginner4x4 wrote:
how much would it be to replace the syncro's in the gearbox ??
It sounds like the clutch could be near the end of it's life. Do you know how old it is? But before you do anything, change the oil and see what happens.
You will be looking at a fair bit to do the syncro's! Ring the Diff and Gearbox Shop in Wilston (3356 8397) and talk to Steve. Mention you talked to Vaughan (me) from Sargent and he will look after you.
Post Posted: Sat Jun 20, 2009 12:30 pm
x2 ended up needing a new clutch though.
Vehicle: LJ20 LJ50
Post Posted: Sat Jun 20, 2009 4:10 pm
Learn to double clutch and you won't need synchros :-)
Camels have nice toes
Post Posted: Sat Jun 20, 2009 5:42 pm
That or just flat change :lol: :lol:
Post Posted: Sat Jun 20, 2009 6:44 pm
thanks guys will head in and see him in febuary (as im in tomor till then)(or could see him in nov on my time off) and see what he can do
but will be changing all oils and filters when i get home
Post Posted: Mon Jun 22, 2009 10:18 pm
i just had a thought would it be cheaper to get another gear box (about $450-$500) or just get mine fixed if it is the synchros
Users browsing this forum: No registered users and 231 guests
