It is currently Thu Oct 22, 2026 12:32 am
Vehicle: 2000 Suzuki Grand Vitara
Post Posted: Fri Aug 19, 2016 7:37 pm
Hi All.
I know ive been asking a lot of questions on this site and appreciate all the feedback.
Ive done a search on this but cant fine anything.
Im going to be installing a weber on my g16a in my Sierra and was wondering which of the 2
outlets on the fuel pump do I use and where do I plumb the other?
Also do I just block off the fuel return line?
Thanks in advance and appreciate all the help i've received here.
Chris.
Post Posted: Sat Aug 20, 2016 12:27 am
Hey!!
I'm not familiar with the G16A sorry but I do run a Weber on a G13BA.
I don't think you'd need to block off the fuel return line, there needs to be somewhere for the fuel to go when the needle valve closes off.
Not sure I can help with which output to use. Perhaps install a T piece and run both into the Weber inlet?
Vehicle: SJ80, SE416
Post Posted: Sat Aug 20, 2016 8:48 am
There is only 3 fuel hoses on the pump - inlet from tank, return to tank, outlet to carby. A small hose without a barb on it is a vent and shouldn't be connected to anything.
Post Posted: Sat Aug 20, 2016 9:14 am
Hi.
The g16 has 2 outlets, I believe one is for the primary and one for the secondary on the Mikuni
Post Posted: Sat Aug 20, 2016 11:44 am
Of that be the case (and I don't know that pump specifically) I'd connect them both by T piece
Users browsing this forum: No registered users and 153 guests
