some one went to a friends car suzuki vitara G16a pulled the lines off and connected the fuel hoses to the 2 bottom lines which filled up the manifold with fuel. Then would not return her calls. I found hoses connected where they should not be and others hidden. I know these 2 are vaccumm hoses. 1 goes to the distributor. the second I cannot find another connection, would this go to the A/C through the bulk Head? secondly the fuel lines am I guessing right that the top is fuel in and second line down fuel out? The feul pump has for connections on it 1 feed in, I am guessing the 1 on the bottom is a drain , but what is the one facing the guard next to the feed in ? is it another return to tank if so does it require a T peace connection? any help on this would be great..
