Vehicle: 2000 Suzuki Grand Vitara
Posted: Wed Aug 10, 2016 4:09 pm
Hi All.
Just wondering if the port size on the inlet manifold of a g13a is the same as on a g16a?
I know there is a difference on it where the carby bolts up re water jacket but not sure of ports.
I have a g16a in my Sierra now and a spare g13a manifold in the garage that I want to do some mods on and install a weber, but not sure on the port sizes being the same.
Personally I wouldnt bother. While i investigated a lot of options and did some testing and work with the stock sierra carby and a few other things, in hindsight I know I should have saved the coin and gone g16b sooner. All that other shit wasn't worth the time, effort and $.
I know now (on my 4th sierra) to tolerate a sh*tbag running carby g13a until I can g16b it.
Joined: Tue Jun 09, 2009 11:30 pm Posts: 1009 Location: Sydney -ish
Vehicle: 92 Suzuki Sierra
Posted: Fri Aug 19, 2016 4:17 pm
from memory its a 1mm difference i think the sierra manifold is better as the 4 intake runners are even length using epoxy putty i added certain features that the g16a intake had to the sierra one
smaller chamber below carb with less dead zones, sort of like an internal throttle plate spacer. Done it to two intakes. Held up the for the last 5 years.
Users browsing this forum: Google [Bot] and 140 guests
