It is currently Thu Oct 22, 2026 1:17 am
Vehicle: 2000 Suzuki Grand Vitara
Post Posted: Tue Sep 13, 2016 5:39 pm
Hi all.
I just got it back My Suzuki Sierra 88 WT back from the tuner, it is running a 1.6 with 32/36 weber, extractors and 29" tires, 3.7 diff ratios.
Was sitting on 100km/h at 4000RPM. With the tire change i know the speed would be out and that would be about 110km
Thing the RPM's are high and was looking at what I can do the fit it without going back to the 26"
Thks
Chris
Post Posted: Tue Sep 13, 2016 6:06 pm
What size tyres are you running?
If your lookin at dropping the revs you need to increase tyre size, not decrease it. Are you running reduction gears in your transfer?
Post Posted: Tue Sep 13, 2016 6:30 pm
Tried 5th gear?
Post Posted: Tue Sep 13, 2016 6:33 pm
Nothing wrong with 4000rpm at 110
In fact id say its spot on
Vehicle: SJ80, SE416
Post Posted: Tue Sep 13, 2016 6:51 pm
Stock Coil Sierras run 4000RPM at 110hm/h. Perfect.
Post Posted: Tue Sep 13, 2016 6:56 pm
My jimny does 4150@100kph and I am about to set off on its third half lap of oz.
Post Posted: Tue Sep 13, 2016 9:29 pm
Hi all.
29" tires. Don't believe it has gear ruduction
In the transfer. That was 5 th gear lol
Post Posted: Tue Sep 13, 2016 10:08 pm
My WT sierra with 31's and 5.14 tcase gears with 1.6efi turns about 3100rpm at 90km/hr in 5th.
I do know that at 5200rpm i'm doing 141km/hr (GPS confirmed rather than speedo).
It's been ages since i sat on 110 so i'm unsure what my RPM would be there, but maybe the above will help.
Maybe you've got the switched NT tcase which is giving you some more reduction?
Post Posted: Wed Sep 14, 2016 6:57 am
Provided it is 4000 rpm or so at 100 km/h by gps and you are in 5th with 29" tyres.
Perhaps it has 5.12 diff gears, or possibly (less likely) a combination of xfer and vitara/gv diff gears.
Post Posted: Wed Sep 14, 2016 8:09 am
yeah as i told you on facebook those revs arent right for the gearing you think you have.
so you are either going faster than you think or some where your gearing is different.
a 1 litre transfer case and doing 115 kmh would come close to what your seeing rev wise
Post Posted: Wed Sep 14, 2016 8:17 am
Yeah u gotta use gps to check speed
Mines nearly 15 km out at 110
Post Posted: Wed Sep 14, 2016 8:59 am
Yep, gearing is not standard.
Post Posted: Wed Sep 14, 2016 9:33 am
It gearing was standard revs would be 3265
Post Posted: Wed Sep 14, 2016 9:41 am
Hi All.
Appreciated your feed back. I can confirm that the diff ratio is 3.7 as I changed them recently
as the original ones had shit themselves.
The transfer case is another thing. Not sure what previous own did there.
Ill gps the speed and get back to you all.
Thks.
Post Posted: Wed Sep 14, 2016 10:11 am
Just stick 31's on it and call it good =) lol
you have a 1.0 transfer or 4.1 transfer gears. If you're reported speed and revs are accurate.
Post Posted: Wed Sep 14, 2016 2:22 pm
Low range RPM and speed figures would identify if it's got 4.1 tcase gears or not.
Post Posted: Wed Sep 14, 2016 4:37 pm
Hmm, in front of my gearing calculator.
You were seeing 4000rpm at an indicated 100km/h on the speedo, yes? (not actual road speed measured with a GPS?)
That means tyre size and diff gears aren't relevant. The only thing that changes the ratio of speedo reading to engine revs are transfer gears.
With my calculator, it looks like you have 6.5:1 transfer gears in the car. I get 4070rpm@100km/h shown on the speedo with 6.5:1 transfer gears in the car.
With your tyres in the mix (assuming they are actually 29") revs at an actual 100km/h will be 3645rpm which is pretty much spot on.
you can check this easily. Put the car in 4L. Leave the front hubs unlocked. Jack one rear wheel off the ground (assuming you don't have an auto locker or spool). chock the other wheels.
Turn the front or rear driveshaft 1 turn. The input shaft from the gearbox to the transfer should turn 6.5 times.
These calculations are only valid if you're talking about speedo reading and not speed via GPS. If it's actual road speed you have even more gearing reduction so the diffs couldn't be 3.7.
Post Posted: Thu Sep 15, 2016 12:37 pm
Hi.
These were speedo reading of 100km tacho around 4000rpm and tires are 255/70/15 which
makes them about 29.1"
I guess its a bonus that it has gear reduction. Wasn't told it had them when i purchased the car about 6 months
ago.
Appreciate all you info, especially you Steve you've been a great help.
Chris.
Post Posted: Thu Sep 15, 2016 3:09 pm
Get a gps on that bad boy your speedo at 100 is in reality prob closer to 110/115
Vehicle: Vitara 1994
Post Posted: Sun Sep 18, 2016 3:36 am
cyprus73 wrote:
Hi.
ago.
Chris.
Throw on a set of 31's and call it a day
Users browsing this forum: No registered users and 172 guests
