| Factory bump stops https://auszookers.com/forum/viewtopic.php?f=5&t=53653 |
| Author: | bogga [ Thu Dec 15, 2016 7:07 pm ] |
| Post subject: | Factory bump stops |
How much, if any, do the factory rubber bump stops compress under full compression with total running weight? |
| Author: | Gwagensteve [ Thu Dec 15, 2016 9:31 pm ] |
| Post subject: | Re: Factory bump stops |
At least 50% |
| Author: | bogga [ Fri Dec 16, 2016 5:16 am ] |
Thanks Steve. Bit more than i assumed. |
| Author: | JrZook [ Fri Dec 16, 2016 10:37 am ] |
Gwagensteve wrote: At least 50% The standard ones? |
| Author: | Gwagensteve [ Fri Dec 16, 2016 11:47 am ] |
My rear end is currently sitting on the bumpstops. (Springs removed) they have compressed 50% of their free height- to the base of the angled section. |
| Author: | bogga [ Fri Dec 16, 2016 1:08 pm ] |
Gwagensteve wrote: My rear end is currently sitting on the bumpstops. (Springs removed) they have compressed 50% of their free height- to the base of the angled section. So based on that they would compress more than 50% in a situation where all the weight of the car was on one corner (on a incline/decent 4wding)? |
| Author: | Bruce [ Fri Dec 16, 2016 5:29 pm ] |
Are you trying to get more compression out of them or less? I only ask as I can make them harder or softer if needed. |
| Author: | bogga [ Fri Dec 16, 2016 6:04 pm ] |
Using stock mounts. Was just curious as to the compression for when I set up the suspension and body. I do tend to overthink things but better than putting no thought into a build. |
| Author: | Gwagensteve [ Sat Dec 17, 2016 9:35 am ] |
Set it up metal to metal. |
| Author: | MrRocky [ Sat Dec 17, 2016 1:41 pm ] |
When they regularly get compressed to that point they split, been through a couple sets now. Interestingly the later model wt's run a rounder type bumpstop thats seemed to last well |
| Author: | sideways [ Sun Mar 26, 2017 3:29 am ] |
I crushed a Sierra front bumpstop in my 20T press today. It's from an early 1l so it's probably harder than most. Uncompressed about 45mm tall. Crushed just about as hard as the press will go, 20mm. It compressed easily until about 25mm when it got quite hard. I've crushed quite a few bumpstops in the press now and it's been the same with all the block/non-progressive bumpstops, a million pumps with no effort and then within a few pumps it's basically solid. They always go to around half their height. Progressive bumpstops on the other hand really seem to do what they say on the box, progressively get harder. I've never crushed a progressive one to the maximum capacity of the press (they look like they're going to pop and they're to valuable to me) but they don't seem to have an obvious hard stop like block bumpstops do. I was using a flat plate so the round diff housing will punch into it a bit easier, I reckon 20mm is a safe height to base shock selection off. Might try a rear one later. |
