It is currently Thu Oct 22, 2026 4:10 am
Vehicle: Suzuki jimny
Post Posted: Fri Jan 06, 2017 11:32 am
Hey guys what tyre pressure should i pump into my Geolanders all terrain on my Jimny? Cheers
Post Posted: Fri Jan 06, 2017 12:17 pm
Approximately what's on the placard.
Vehicle: Suzuki Jimny
Post Posted: Fri Jan 06, 2017 3:55 pm
Size is more important then brand
hillbilly 2 wrote:
And this ^^^^ clown is why auszookers will never be taken seriously
Vehicle: Vitara 1994
Post Posted: Sat Jan 07, 2017 1:44 am
26 onroad
10-12 offroad for now
Post Posted: Sat Jan 07, 2017 7:18 am
The OP might not sit on 140km/h cruising though, and with the stiffer construction of an LT tyre they might not need as much as 26psi.
Post Posted: Sat Jan 07, 2017 9:41 am
Have a guess at what pressure the tyre placard says
Post Posted: Sat Jan 07, 2017 10:16 am
Yeah, I reckon it says 26. And that's for a P-metric tyre with no load rating. That's why I said "approximately"
If the 4psi technique was applied to those geolandars, I bet they'd need a lot less than 26.
Post Posted: Sat Jan 07, 2017 4:40 pm
True, but the OP is looking for a number to start. So I gave it to him.
No idea what load rating the OP has, but geolanders ATs' in general are a bit softer than other AT's on the market.
Vehicle: Suzuki Super Carry
Post Posted: Mon Apr 10, 2017 10:00 am
Sorry to post in old thread
What tyre pressure should I run with 235/75/15 Geolanders AT in a Vitara SWB on road?
Post Posted: Mon Apr 10, 2017 4:07 pm
There's the answer.
If you want to try an experiment, you can try the 4psi "rule" - this will likely indicate a pressure a few psi under the placarded pressure due to the stiffer tyre you've fitted. .
There's also some personal preference involved, but not much. In my cars I generally run at the "high load/high speed" recommendation on the placard because I like a firmer feel on cornering, but I don't on my defender because it takes the rear tyres to something like 65psi.
Users browsing this forum: No registered users and 170 guests
