Vehicle: 97suzi 5door JLX with G16b mo
Posted: Sun Feb 12, 2017 3:42 pm
I have a 97 Vitara SE416 with the G16B motor. During the 42 degree heat we had the other day it started running rough at idle through to 2500 R.P.M., it also smelt strongly of petrol. It is not using oil or leaking it,plugs are OK but dry,timing is correct. any ideas. If not can someone suggest a good suzi mechanic in Adelaide. Ta
Users browsing this forum: Google [Bot] and 231 guests
