It is currently Wed Oct 21, 2026 6:10 pm
Vehicle: 1998 "Coily"
Post Posted: Sat Feb 25, 2017 7:04 am
he guys i have some weird stuff going on with my sj80 radio. here's whats up:
radio turns off whenever the brake is applied
radio turns off whenever the turnsignal is on
radio turns off when ever headlights are on
head light dem when vehicle is in gear and here is a load on the engine
horn wont work when he headlights are on and ac is on
i just replaced he battery , could the problem be the altenator or voltage regulator?
Thanks
Post Posted: Sat Feb 25, 2017 7:23 am
Check the earth from battery to firewall. If stock then replace it with one that is a lot bigger
Post Posted: Sat Mar 04, 2017 6:04 am
I recently replaced but with a new stock size one. Do you think I should go biguerilla anyway?
Vehicle: Suzuki Jimny
Post Posted: Sat Mar 04, 2017 6:52 am
Couldn't hurt to put a bigger one on. Also would be worth checking the fuse link
hillbilly 2 wrote:
And this ^^^^ clown is why auszookers will never be taken seriously
Post Posted: Sat Mar 11, 2017 9:24 pm
Also noticed when driving at night the headlights are brighter when the clutch is fully depressed vs when no pressure on the clutch and driving the headlights dim.
Post Posted: Sat Mar 11, 2017 10:35 pm
You definitely have grounding issues - there should be a couple of relatively heavy cables from the battery negative to the chassis/body and also one of the starter or bellhousing bolts - that second one is what's causing that change in brightness when you depress the clutch
I would get that seen to ASAP - if you're not grounded properly there, you can end up burning the clutch cable when you crank the engine.
Post Posted: Sun Apr 02, 2017 3:27 am
Update. Turns out the body didn't have a strong enough ground. I ran a wire straight from the battery to the body and problem solved. Thanks for the help
Users browsing this forum: No registered users and 82 guests
