It is currently Wed Oct 21, 2026 12:23 pm
Post Posted: Fri Mar 03, 2017 7:17 pm
Hey people just after some knowledge and pics of aircon systems to put into my ute what shhould i use do i take it out of a jimny or something ??????
92sierra ht 33s 5in lift 2in zorst gti powered
Post Posted: Fri Mar 03, 2017 7:21 pm
There were dealer installed 1.0 A/C kits- I've seen a 1.0 with one.
No, jimny and 1.3 sierra isn't the same.
Post Posted: Fri Mar 03, 2017 7:25 pm
I have an injected g16a in it now just wanted to see about aircon lines and pump and the cluster in the cab
Vehicle: sierra
Post Posted: Fri Mar 03, 2017 8:56 pm
I used an aftermarket evaporator kit, they don't fit well in a Sierra as they bolt under the dash and they are pretty expensive , I have no pics, but you need to size your compressor, receiver, TXV and condenser to suit, also getting the condenser in can be annoying. I did have mine behind the cab with a fan, however you need to protect the lines and this also means a larger refrigerant charge
Vehicle: Drover pickup turk
Post Posted: Sat Mar 04, 2017 7:09 am
viewtopic.php?f=4&t=47711
I like the tuna here
Users browsing this forum: No registered users and 116 guests
