It is currently Wed Oct 21, 2026 11:12 am
Post Posted: Fri Mar 24, 2017 8:36 am
Recommendations on a efficient radiator cooling a G16b with vit fan and a AW4 pushing 33's with a set of 6.5's. Will have a winch up front with a auto cooler in front of radiator.
Would rather spend the dollars on a good set up as opposed to running the red light on a cheap ass set up.
Phuck Photobucket
Post Posted: Fri Mar 24, 2017 9:12 am
I never had any issues with my 1.6. 4.9s, 33s, with the stock rad.
when i fitted the j20 i had the stock rad tripple cored and it was fine too.
Post Posted: Fri Mar 24, 2017 9:15 am
I'd agree. Stock radiator should be fine.
Post Posted: Fri Mar 24, 2017 9:17 am
Stock 1.6 rad?
I have one out of donor car but it just looks to big to fit?
Phuck Photobucket
Post Posted: Fri Mar 24, 2017 9:20 am
Stock 1.3.
The vitara radiator isn't a good fit in my opinion. I've seen it done but it needs to be offset and tilted which vastly complicates shroud fitment. The shroud and fan is more critical to cooling performance than the radiator size in my opinion.
Post Posted: Fri Mar 24, 2017 9:30 am
Great. Complications is not what I'm after. Definitely understand the importance of the shroud, I'm over the top when it comes to the cooling system to the point where I buy the best concentrate and will only mix with demineralised water.
Coffs wheeling is slow and long and I've found a good operating cooling system is paramount especially in the warmer months.
Thanks for the replies.
Phuck Photobucket
Users browsing this forum: Google [Bot] and 275 guests
