There are quite a few cheap Jimny snorkles for sale on Ebay (around $100). Has anybody fitted one of these? Are they of a 'you get what you pay for' quality standard and better avoided?
I am fitting one I bought from wildplanetimport on Ebay. It was just over $80 delivered. (Ebay special with $20 discount) It looks good and solid. I can't fault it for the price. The template is spot on - I have a 2011 Jimny without the turbo looking bonnet. It involved removing the inner lining from the mudguard to get at the mounting bolts. There is also a canister ( some air or vacuum related item I think) fitted inside the mudguard which I needed to undo before I could remove the existing air intake thingy. All this is easier without the RHS front wheel and the battery. I test fit the snorkel and found it all good. I painted the holes I drilled and cut, and will reassemble everything tomorrow. Oh, I locktighted the supplied 6mm studs into the snorkel body to avoid having them coming loose later and will silicone the entry point into the aircleaner body. No dramas..
Users browsing this forum: No registered users and 270 guests
