Joined: Sun Nov 18, 2012 12:03 pm Posts: 66 Location: New Zealand
Vehicle: 95 SJ70, 96 Escudo v6
Posted: Sun Jun 04, 2017 7:13 am
Hi there,
I have seen posts about this a long time back but have not had much luck with the search.... Are Vitara and Samurai rear diffs similar? I have a broken spider gear in my SJ70 and I know where a LSD from a Vitara is, If I was to use only the inner LSD part? (Sorry no so good on terminology) Could I install my Ring gear on it and put it in the SJ70 housing. I guess the ring gear might need a shim, and backlash will need to be set etc.
Users browsing this forum: No registered users and 257 guests
