https://auszookers.com/forum/
Seized flywheel dust cover bolt
https://auszookers.com/forum/viewtopic.php?f=5&t=54299
Author:  davemcgrath [ Sun Jun 11, 2017 7:15 pm ]
Post subject:  Seized flywheel dust cover bolt
Today I was disconnecting everything from the 1.3L G13BA in my Sierra (I'm starting a coil pack Baleno conversion).
So far all the fasteners have come off cleanly, including the exhaust fasteners :woohoo:.
I got the driver side flywheel cover bolt off, but the passenger side bolt rounded off unexpectedly :x .
I cut a slot into the bolt head with a dremel wheel and have been striking the slot at an angle with a flathead driver and a hammer. This method has worked for me before, but so far it hasn't turned at all.
The rear of the thread hole is visible so I sprayed a bit of trans. fluid/acetone mix in there, but it still hasn't loosened.
Any suggestions on how to get it out?
Image below.
Author:  Gwagensteve [ Sun Jun 11, 2017 8:47 pm ]
Post subject:  Re: Seized flywheel dust cover bolt
Vicegrips on the head. It's generally a one shot deal so make sure the vicegrips are sharp and they go on very tight. Should move a bolt that's only 6mm.
Author:  MrRocky [ Sun Jun 11, 2017 9:41 pm ]
Weld a nut on it
Author:  fordem [ Sun Jun 11, 2017 10:55 pm ]
Author:  cairns27 [ Mon Jun 12, 2017 8:38 am ]
Six sided spanners can often grip rounded bolts.
bye
Author:  davemcgrath [ Mon Jun 12, 2017 9:02 pm ]
Tried the vise grips with no luck.
I'll try to borrow a welder next :roll:
Author:  davemcgrath [ Tue Jun 13, 2017 5:53 pm ]
Filed down the sides of the bolt head and managed to get a much better grip on it with the vise grips.
Bolt now removed. Armsup
