It is currently Mon Oct 12, 2026 2:46 am
Vehicle: 1995 Suzuki Sierra SJ70
Post Posted: Sun Jun 11, 2017 7:15 pm
Today I was disconnecting everything from the 1.3L G13BA in my Sierra (I'm starting a coil pack Baleno conversion).
So far all the fasteners have come off cleanly, including the exhaust fasteners :woohoo:.
I got the driver side flywheel cover bolt off, but the passenger side bolt rounded off unexpectedly :x .
I cut a slot into the bolt head with a dremel wheel and have been striking the slot at an angle with a flathead driver and a hammer. This method has worked for me before, but so far it hasn't turned at all.
The rear of the thread hole is visible so I sprayed a bit of trans. fluid/acetone mix in there, but it still hasn't loosened.
Any suggestions on how to get it out?
Image below.
Post Posted: Sun Jun 11, 2017 8:47 pm
Vicegrips on the head. It's generally a one shot deal so make sure the vicegrips are sharp and they go on very tight. Should move a bolt that's only 6mm.
Post Posted: Sun Jun 11, 2017 9:41 pm
Weld a nut on it
Post Posted: Sun Jun 11, 2017 10:55 pm
Post Posted: Mon Jun 12, 2017 8:38 am
Six sided spanners can often grip rounded bolts.
bye
Post Posted: Mon Jun 12, 2017 9:02 pm
Tried the vise grips with no luck.
I'll try to borrow a welder next :roll:
Post Posted: Tue Jun 13, 2017 5:53 pm
Filed down the sides of the bolt head and managed to get a much better grip on it with the vise grips.
Bolt now removed. Armsup
Users browsing this forum: No registered users and 221 guests
