[ 7 posts ] |
Print view
Previous topic | Next topic
| Author |
Message |
got_bar_work
Joined: Sat May 15, 2010 8:30 pm Posts: 2214 Location: Brisbane
 Posted: Wed Jun 28, 2017 2:16 pm |
Does any one know the distance between the rear coil mounts on a gv at full bump. Im looking for new coils as i over estimated the weight when i got the last ones and need to drop it like 3 in. Right now im running 150lbs 3"id 18" long. They are a great length but are to high a rate as they only compress 4.5in at ride height. Can any one see a problem with going down to 100lbs coils and getting shocks valved to suit
Gwagensteve
Joined: Thu Feb 26, 2009 10:30 pm Posts: 13013 Location: Melbourne
 Posted: Wed Jun 28, 2017 2:38 pm |
Running deeply compressed springs with very soft rates can feel odd- with very large changes in ride height with only small weight transfer. It's part of the reason many lift springs are shorter and run a higher rate. Squat and roll gets super exaggerated.
You'll lower the car 2.25" if you drop to 100lb springs.
got_bar_work
 Posted: Wed Jun 28, 2017 3:54 pm |
Would a rear swaybar and playing with angle of top links fix the problems. Any one know what the rate of the calmini springs.
Gwagensteve
 Posted: Wed Jun 28, 2017 4:12 pm |
They're pretty soft. I haven't specced the ones I have but I think close to 100lb is likely. Most people with LWB's find them far too soft.
A swayer might help handling, but it won't help the huge changes in ride height with relatively small load changes - you'll lose 1" per 100kg
got_bar_work
 Posted: Wed Jun 28, 2017 5:51 pm |
Im going to run a 10in travel airbag off the diff center to allow for camping loads or to lift the car up if i belly out on something
Gwagensteve
 Posted: Wed Jun 28, 2017 6:02 pm |
interesting. you may still want a swaybar.
got_bar_work
 Posted: Wed Jun 28, 2017 7:03 pm |
I would say so. Ive been reading the spring thread on pirate and want to try something new instead of the old traped short and hard coil idea that everyone used to use.
[ 7 posts ] |
Users browsing this forum: Google [Bot] and 134 guests
