Vehicle: Suzuki Grand Vitara 04 manual
Posted: Thu Jul 06, 2017 4:14 pm
I need to replace mine but have noticed some kits have a half moon seal some don't. Do I need one for this motor. All kits have gasket, tube seals and nut seals but not all have a half moon seal.
Hey Max , Quite often the aftermarket gaskets have the "D" seal incorporated into the rocker cover gasket itself, same with the plug tube seals , some have the plug tube seals attached with a thin section of rubber between the gasket and seals. if the picture of the one you want to order doesnt have a clear image of the gasket with incorporated "D" seal or a seperate "D" seal, then they are not hard or expensive to source seperately.
Your engine does use a seperate "D" seal from factory.
_________________ Dr Suzuki - South east Queenslands most experienced mobile Suzuki mechanic. Please like and share my facebook page - www.facebook.com/suzukimechanic
Users browsing this forum: No registered users and 203 guests
