Page 1 of 1
[ 4 posts ] |
Print view
Previous topic | Next topic
| Author |
Message |
bristlenose2008
Joined: Sun Jan 23, 2011 12:01 am Posts: 194 Location: Gosford
Vehicle: Vitara 1995
 Posted: Thu Aug 03, 2017 5:24 pm |
Guys, i want to register my car and it needs a blue slip first. Pretty much everything has been returned to standard or within legal upper limits except for bumper bars, rock sliders.
Am i better off getting engineers certificates for anything in doubt up front, or take the risk of being rejected for a blue slip.
Getting pink slips is much easier than blue slips hence my question.
Would i still run into issues with blue slip with an engineers certificate?
BlueSuzy
 Posted: Fri Aug 04, 2017 1:39 pm |
Pretty much everything has been returned to standard or within legal upper limits except for bumper bars, rock sliders. Pictures of bars? Rocksliders should be fine as long as they aren't welded to the chassis.
Am i better off getting engineers certificates for anything in doubt up front, or take the risk of being rejected for a blue slip. If its stock, everything working as it should(no worn parts), clean, It should pass
Getting pink slips is much easier than blue slips hence my question. Not really.
Would i still run into issues with blue slip with an engineers certificate? Engineer is for mods, You can still fail a blueslip if wipers arent working, depends on if engineer checks it, otherwise they should do the blueslip too
Mine went from an unregistered rust bucket- engineered- Then blueslip = Rego
squibby
Joined: Wed May 11, 2011 3:13 am Posts: 645 Location: Brisbane
Vehicle: On the lookout
 Posted: Thu Aug 17, 2017 2:32 pm |
How did you go? Pass?
Blue slip is more stringent, there are no myths around this, its fact. Should be okay with metal work on the car. As long as its commercial looking, not homemade, or so much of it that it looks like it could be pushing the GVM with passengers.
Rosk areas are lifts exceeding 50mm with tyres exceeding 50mm, (75mm total ride height change). LED indicators or Headlamps or non standard mirrors, seats or steering wheels or roll bars.
On a safety cert (pink slip) they wont care, for Blue slip they most certainly will.
_________________ Crispy old grand vitara
just_cruizin
Joined: Sun Jun 25, 2006 11:30 pm Posts: 2867 Location: here
 Posted: Thu Aug 17, 2017 3:44 pm |
I'm not 100% familiar with NSW but if they are following the NCOP for mods, which I think they are, squibby is correct on the lift 75mm total including tyres, suspension and bodylift for non-engineered modification, anything above requires engineering approval, up to maximum 50mm diameter tyre increase (previously this was more), 50mm maximum body lift, suspension I am unsure of.
Safety cert or Blue slip will still pick up indicators not functioning correctly, be that rapid flash due to LED or not. Headlamps need to be ADR approved, should be picked up in either inspection as would seats and steering wheel.
Bar work regardless of store bought or homemade need to comply with certain regulations around radius and width of leading edges, if the home made stuff has the correct requirements no dramas.
_________________ greenzook89 wrote: 31zook wrote: Makes me want something similar
Page 1 of 1
[ 4 posts ] |
Users browsing this forum: Google [Bot] and 175 guests
