It is currently Thu Oct 08, 2026 6:00 pm
Vehicle: Sierra g16 efi..and Sierra GTi
Post Posted: Sat Aug 12, 2017 2:09 pm
So thanks to the helpful folk here. Zuk92 now has new back brakes that actually work...no leaking slave cylinders or axle seals and the handbrake actually works well.... however....anything a harder than normal braking causes the rear passenger side to lock up... I am assuming this is because all the heavy stuff, eg,,Battery, driver, spare wheel etc is all on the drivers side so the most likely slider is the rear left. We tested this theory by putting my heavy son in the rear left seat and the problem wasn't nearly so bad. Do these have a brake proportional valve that can be adjusted (92 wide)...and if so where is it located how is it adjusted. Cheers..
Users browsing this forum: No registered users and 184 guests
