It is currently Fri Oct 09, 2026 3:06 am
Vehicle: 98 Jimny
Post Posted: Tue Aug 15, 2017 9:38 pm
Hello everyone, I am Chasing the Ratio gears for Manual and Auto gear box for the following.
G13ba(Sierra), G16b(vitara), J18a(Vitara), J20a(Vitara) Please correct if the following are wrong.
All advice will be greatly appreciated or links.
Gear // Manual // Auto
G13BA
1st ??
2nd ??
3rd ??
4th ??
5th ??
R ??
G16B
1st 3.65 // 2.83
2nd 1.95 // 1.49
3rd 1.38 // 1.00
4th 1.00 // 0.73
5th 0.86 // -----
R 3.67 // 2.70
J18A
1st 3.55 // 2.81
2nd 1.90 // 1.48
3rd 1.31 // 1.00
4th 0.97 // 0.73
5th 0.82 // -----
R 3.25 // 2.77
J20A
1st 3.54 // 2.80
2nd 1.90 // 1.47
3rd 1.31 // 1.00
4th 0.96 // 0.73
5th 0.81 // -----
R 3.25 // 2.76
Thanks,
Michael
Vehicle: zook
Post Posted: Tue Aug 15, 2017 9:53 pm
The ratios I have noted down for the J20A boxes are this:
Type 4 A/T 5 M/T
Gear ratio 1 2.826 3.652
2 1.493 1.947
3 1.000 1.379
4 0.685 1.000
5 - 0.795
Reverse 2.703 4.000
Final gear ratio 4.875 4.875
Post Posted: Tue Aug 15, 2017 10:27 pm
1.3 Sierras had 2 different ratios, SJ50s had a taller 5th gear.
Vehicle: 98 Jimny
Post Posted: Tue Aug 15, 2017 10:34 pm
Thanks Heaps, well all the info i have is from USA forums so im not sure if that would make any difference.
Vehicle: zook
Post Posted: Wed Aug 16, 2017 10:29 am
worth noting, almost every 5 speed manual box 4th gear will be 1:1, Except the g13b jimny where 5th was 1:1.
I would be skeptical of any table that does not include a 1:1 ratio for a manual box. This is not a "gear" as such, it is a direct coupling of the input and output shafts.
Post Posted: Wed Aug 16, 2017 11:48 am
Also worth noting I believe the sj80's had different gearbox ratios in 2nd and 5th (maybe others)
Vehicle: 98 Jimny
Post Posted: Sat Aug 19, 2017 12:42 am
Do any of you know what the stock Vitara transfer case gears are?
Post Posted: Sat Aug 19, 2017 10:03 am
1:1 High, something like 1.96:1 Low
Vehicle: 98 Jimny
Post Posted: Sat Aug 19, 2017 11:10 am
Cheers and Steve, oh and is that for all vits with a J series in them?
Post Posted: Sat Aug 19, 2017 1:10 pm
Yes. All the same.
Post Posted: Sun Aug 20, 2017 9:26 am
I'm all for having accurate information out here in a forum, but what's the practical application? What gearing problem are you trying to overcome?
PS I'm slightly dubious about some of the answers here. The J18 figures (so for a USDM Vitara sport) show a 0.97:1 4th gear and J20 at 0.96. That would be a very technically difficult ratio to achieve for little to know practical purpose. I can't imagine why Suzuki would engineer two different gear sets for two almost identical cars in every other way.
Post Posted: Sun Aug 20, 2017 10:50 am
AFAIK the manual transmissions used with the J18 & J20 engines are "conventional" five speed transmissions with a direct drive (1:1) fourth gear
Post Posted: Sun Aug 20, 2017 11:11 am
That's what I would have thought.
Vehicle: 98 Jimny
Post Posted: Sun Aug 20, 2017 1:20 pm
I just got this Info from another Forum "AerioStyles" and was just confirming that info on here instead of asking like most people do i was trying to research then confirm. As for Application i don't really like say much about my build's because most the time you post it up people just destroy you and say why would you spend so much money etc..... So if i talk about builds it in PM's. Ill send you a message Steve about the build and see what you think.
Just my 2c tho.
Users browsing this forum: No registered users and 224 guests
