It is currently Fri Oct 09, 2026 4:42 pm
Vehicle: 96 tin top sierra 31's omes
Post Posted: Sun Aug 27, 2017 6:42 pm
Hey
While out driving at bylong creek. I had issues when crawling up rough steep road if i drove lower in the revs it would die unless i gave it a few pumps on the accelator. When i let it idle it dies, has trouble starting the first couple of times. Then runs fine. But sometimes rough idle.
Also while driving on the motor way i have noticed after a long slow incline at 110 if i back off the is a sudden jerk. But dissappears if i accelerate again.
Things to know.
Fuel tank is fuel
Serviced day before trip but didn't affect issue.
Have noticed a crack on the shaft below coil pack.
Okay and the engine.
G16a block
Baleno head and cover.
Jimny intake
Coily fuel tank
Baleno extended sub pump.
Im going to pull the sensors i can get to and clean them. And look for a cheap 2nd hand coil pack to replace the cracked one.
Thanks
Jake
Sent from my SM-G900I using Tapatalk
Users browsing this forum: Google [Bot] and 114 guests
